OID for Ethernet interface... PIX515
jins
Beginner
Beginner
I would like to monitor the ethernet interfaces on a PIX 515 firewall with Software version 6.0(1). I just need to get the UP/DOWN status of the interface which I'm monitoring from a SNMP monitoring software. The software needs the OID for the interface.
Thanks for replies
Jins
gfullage
This is just standard SNMP, you can easily find this by doing an snmpwalk on the PIX. Mine shows the following:
interfaces.ifTable.ifEntry.ifAdminStatus.1 = up(1)
interfaces.ifTable.ifEntry.ifAdminStatus.2 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.1 = up(1)
interfaces.ifTable.ifEntry.ifOperStatus.2 = up(1)
or if you want the numbers:
.1.3.6.1.2.1.2.2.1.7.1 = up(1)
.1.3.6.1.2.1.2.2.1.7.2 = up(1)
.1.3.6.1.2.1.2.2.1.8.1 = up(1)
.1.3.6.1.2.1.2.2.1.8.2 = up(1)
Interface 1 is outside, interface 2 is inside.
Recognize Your Peers
