OOB L3 Real IP Gateway - Agent issue
harinirina
Hello all,
We've setup NAC as Out-Of-Band Real IP Gateway. We did the test from a L3 adjacent client.
It's working when login from a web. The user is listed under online OOB user, the pc gets an IP address on the vlan assigned to the user role.
We'd like to use cisco Agent for the L3 adjacent user. But the Agent windows does't pop up.
for the moment, no ACL is configured on the router between the NAC and the user.
Could anyone tell how to troobleshoot / fix this issue?
5 Replies 5
Bobby Meador
You may need to make a few XML edit's also be sure 8905-8906 TCP& UDP can reach the mgmt server. This file can be found in the Cisco Agent dir under Program files. Once you edit the file upload the file back to the CAM (Mgmt) via webpage under Clean Access>Clean Access Agent>Installation.
File = NACAgentCFG.xml
Thanks for your reply.
For the moment, we're using NAC ver4.1.1 (no xml file).
We'd like to use the NAC for both L2 and L3 OOB, Real Ip Gateway.
The configuration we did is as follow :
- The untrusted interface of NAS is connected to a trunk switch port and the trusted to an access switch port.
- The NAS is configured as DHCP server for Auth VLAN
- A route to the IP address of unauthenticated L3 adjacent user is added on the NAS.
- A PBR is configured on the CORE switch and on the edge router to send trafic from unauthenticated user to the untrusted interface of NAS.
what we noticed is that we can ping the IP address of NAS'untrusted interface from L3 adjacent user only after launching ping to this IP on the CORE and the Agent pops up (if no ping, no pop-up).
Could you please tell if there's something wrong or missing on the above steps?
how can we fix this issue.
Well I dont think both layer 2 and layer 3 are going to work. When you add your CAS to the Nac manager it will ask the type of deployment. I am using layer 3 OOB. You also do not need a trunk port with this type of deployment. I would make the untrusted network a SVI Vlan off your core and then lock things down via an ACL. You will need to allow the 8906, 8906 TCP,UDP & 8910 TCP. You will also need to allow all of the MS ports DHCP, DNS. Here is an example of the ACL I use.
    10 permit icmp any any echo-reply
    15 permit icmp any 10.20.1.0 0.0.0.255
    20 permit udp any any eq bootpc
    30 permit udp any any eq bootps
    40 permit udp any any eq domain
    50 permit tcp any 10.20.1.0 0.0.0.255 range 49152 65535
    60 permit udp any 10.20.1.0 0.0.0.255 range 49152 65535
    70 permit udp any 10.20.1.0 0.0.0.255 eq 389
    80 permit tcp any any eq 8905 (116 matches)
    90 permit udp any any eq 8905 (370 matches)
    100 permit udp any any eq 8906
    110 permit tcp any 10.20.1.0 0.0.0.255 eq 389
    120 permit tcp any any eq 8910
    130 permit tcp any host 10.20.1.1 eq 443
    140 permit tcp any host 10.20.1.1 eq www
    150 permit tcp any 10.20.1.0 0.0.0.255 eq 88
    160 permit tcp any 10.20.1.0 0.0.0.255 range 135 139
    170 permit tcp any 10.20.1.0 0.0.0.255 range 1025 1026
    180 permit tcp any 10.20.1.0 0.0.0.255 eq 3268
    190 permit tcp any 10.20.1.0 0.0.0.255 eq 445
    200 permit udp any 10.20.1.0 0.0.0.255 range 135 netbios-ss
    999 deny ip any any
Do you mean we cannot use one NAS for both RIP L2 and L3 ?
I thought L3 could be enabled with L2 RIP by checking the corresponding check box.
Do we need to add static route or ARP on the NAS (for IP address of non-authenticated users) ?
We are using OSPF, we'd like to ask if network IP address of NAS untrusted interface ,NAS trusted interface and non-authenticated users should be configured for OSPF ?
Hello Bobby,
After some labs, we noticed that it is not a problem of vlan or trunk/access.
After adding static route on the NAS, we need to ping NAS'IP address from the switch before we can ping it from L3 adjacent user.
We don't know what's wrong or missing in the conf.
We tried to remove the static route and add ARP on the NAS, we can ping the NAS from L3 user.
Could you please help, what should be done to fix it?
