Outside Interface
scooter817
Level 2
Level 2
what are the commands to configure an interface as the outside interface on a router and leave all others as inside
ip inspect INSPECTNAME in
the easiest way to use that command is to set up your inspection rules and then apply that command on the inside interface.
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_cfg_content_ac_ps6350_TSD_Products_Configuration_Guide_Chapter.html
srue
Level 7
Level 7
can you be more specific? NAT? IOS Firewall? etc?
Or do you mean in general?
IOS Firewall
