Password recovery for Cisco IDS Sensor 4215
ravillal
Beginner
Beginner
I have a Cisco IDS sensor 4215. Don't know what is the O/S that the previous Admin had on it, and of course don't know the passwords. Found this link for the password recovery:
http://www.cisco.com/en/US/products/sw/secursw/ps2113/products_password_recovery09186a0080094e83.shtml
After reading the article it seems that the password recovery can only be done with a Solaris file.
Dumb main question:
Do I need to use a Solaris Machine or will a regular windows machine work with the file?
rwassom
Beginner
Beginner
If a GRUB boot menu appears on the console at some point when you boot the system, it is running some flavor of 4.x software. You can select the second boot option (Recovery) to re-image the sensor and reset the passwords.
If no GRUB prompt is displayed, you will need to re-image the sensor using the new 4.1(4) system image. But first, you need to verify the BIOS version currently installed on the sensor. The BIOS version will be displayed during the earliest part of the boot process. If it is not "5.1.7" (earlier 4215s shipped with version "5.1.3"), you will need to download and install the 5.1.7 BIOS upgrade from:
http://www.cisco.com/cgi-bin/tablebuild.pl/ids-firmware
Follow the instructions in the associated readme file to load the new BIOS. Once you have upgraded the BIOS to 5.1.7, you can TFTP-boot the "IDS-4215-K9-sys-4.1-4-S91a.img" from:
http://www.cisco.com/cgi-bin/tablebuild.pl/ids4-app-recovr
As with the BIOS update, follow the instructions in the associated readme file to install the system image.
Once the system is re-imaged (it will reboot several times first), you can login using the default account/password (cisco/cisco) and run setup to configure the sensor.
-Rusty
Hi Rusty,
excellent information. you really are helping a lot to solve IDS issues. keep it up
Recognize Your Peers
