PIX 501 Password Recovery Problems
bbaxter101
Greetings,
I have read the document on password recovery, unfortunatly the commands that are listed in the document are not available in the PIX that I am using.
The only commands I see are:
enable
login
logout
pager
quit
I can see show as well
checksum
curpriv
history
pager
version
I can't get to any of the commands to connect to the tftp server as discribed in the instructions at:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_password_recovery09186a008009478b.shtml
I have the password recovery .bin file I just can't seem to get it onto the PIX. Any help is greatly appreciated.
varrao
Level 10
Level 10
Hi Brian,
The command that you see in the doc, are in the rommon mode, not in the normal config mode of PIX, you need to reload the PIX, when the PI is booting up , keeping hitting escape key and it will take you to the rommon mode. Then you will find those commands.
Hope this helps.
Varun
Please do rate helpful posts.
Varun Rao
varrao
Level 10
Level 10
Hi Brian,
Hope this helps.
Varun
Varun Rao
This worked perfectly, Thanks
Your Welcom, thanks for the rating
-Varun
Varun Rao
