Ask the Expert- SD-WAN
706
Highlighted
Beginner
PIX 6.3 SNMP MIB, issue with compile CISCO-PROCESS-MIB.oid
Hi, I'm Edgar Servín
I have a Cacti and I need to monitor the CPU of the PIX, I have the OID Number:
cpmCPUTotal5sec     1.3.6.1.4.1.9.9.109.1.1.1.1.3
I used the Cisco SNMP Object Navigator and says:
Compile the MIB
Before you can compile CISCO-PROCESS-MIB , you need to compile the MIBs listed below in the order listed.
Download all of these MIBs (Warning: does not include non-Cisco MIBs) or view details about each MIB below.
How can I do that?
Everyone's tags (6)
1 ACCEPTED SOLUTION
Re: PIX 6.3 SNMP MIB, issue with compile CISCO-PROCESS-MIB.oid
Hi Edgar,
compiling MIBs is only necessary when you use HP OpenView or something similar. With Cacti, I must admit I never used it myself but I am pretty confident that you can just configure the OID in Cacti and it will just do a periodic SNMP query for that object.
hth
Herbert
1 REPLY 1
Hi Edgar,
hth
Herbert
