Pix Booting Problem
manish-young
When i boot my PIX 501, it get stuck over
here
any clue
Regards manish
CISCO SYSTEMS PIX FIREWALL
Embedded BIOS Version 4.3.207 01/02/02 16:12:22.73
Compiled by morlee
32 MB RAM
PCI Device Table.
Bus Dev Func VendID DevID Class Irq
00 00 00 8086 7192 Host Bridge
00 07 00 8086 7110 ISA Bridge
00 07 01 8086 7111 IDE Controller
00 07 02 8086 7112 Serial Bus 9
00 07 03 8086 7113 PCI Bridge
00 0D 00 8086 1209 Ethernet 11
00 0E 00 8086 1209 Ethernet 10
sagdas
Try to go to the monitor mode. Hit the 'esc' key when the pix boots.
if you are able to get there, you can use a tftp server to upgrade the code. Try to upgrade to the same code which is there on the pix.
the best way would be to open a TAC case.
Sagar
I have the same problem for PIX 525. When I hit the 'esc' key I get the test menue
Compiled by morlee
256 MB RAM
Testing mode menu:
1. Test floating
2. Test protected mode.
3. Exhaustive Test first 640k.
4. Exhaustive Test high memory.
*. Start all tests (Any key to stop tests).
C. Continue.
I hope we could solve that also
I was able to fix it,
What you need to do is open PIX Firewall Chassis,
Next to Bios Bettery, there is a jumper. Just change that jumper setting and it should start working
Thanks every one for there reply
Manish Young
