02-10-2004 09:58 AM - edited 02-21-2020 10:09 AM
I'd like to know if, in future versions of the pix firewall software , it will be possible to store RSA public keys on the pix flash memory, to authenticate clients connecting to it via ssh using RSA public key authentication instead of a password.
Thanks for your attention.
02-11-2004 12:47 AM
Yes you can save the generated RSA key onto the PIX Flash memory. Use command, in config mode after you have generated your key with command: ca generate rsa key
> ca save all
You can view your generated RSA key by issuing command: sho ca mypubkey rsa
Hope this helps, Jay.
02-11-2004 01:33 AM
No,
what I'd like to do is to put the public key of my pc on the pix flash memory, so it could authenticate me by checking that I own the corresponding secret key; such a thing is possible on any other ssh server, and it would be very handy feature to have on the pix firewall, too.
