214
Highlighted
Beginner
PIX VPN Port traffic not transferring...
I have a PIX to PIX VPN established. I can ping back and forth from client to client on their respective network over the VPN. I can get DNS resolution over the VPN. I can even login to a domain across the VPN, however I cannot seem to get any port related traffic to establish. I try using both terminal services and citrix clients to connect to the servers across the VPN, but get timed out on both services.
What is restricting my port traffic? I cant find it.
PIX 515: (servers are on the inside of this network, 10.128.1.0)
PIX Version 6.2(2)
names
name x.x.x.98 GreenBuilding
name x.x.x.126 PalHall
access-list vpn1 permit ip 10.128.1.0 255.255.255.0 10.128.15.0 255.255.255.0
access-list vpn1 permit ip host GreenBuilding 10.128.15.0 255.255.255.0
access-list vpn1 permit ip 10.128.15.0 255.255.255.0 10.128.1.0 255.255.255.0
access-list vpn1 permit ip 10.128.1.0 255.255.255.0 host PalHall
access-list testonly permit ip any any
ip address outside GreenBuilding 255.255.255.248
ip address inside 10.128.1.250 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list vpn1
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.x.100 10.128.1.3 netmask 255.255.255.255 0 0
static (inside,outside) x.x.x.102 10.128.1.4 netmask 255.255.255.255 0 0
static (inside,outside) x.x.x.101 10.128.1.7 netmask 255.255.255.255 0 0
conduit permit icmp any any
conduit permit tcp host x.x.x.100 eq citrix-ica any
conduit permit tcp any eq 3000 any
conduit permit tcp host x.x.x.102 eq citrix-ica any
conduit permit tcp host x.x.x.102 eq 3389 any
conduit permit tcp host x.x.x.100 eq 3389 any
conduit permit tcp host x.x.x.101 eq www any
conduit permit tcp host x.x.x.101 eq 3389 any
route outside 0.0.0.0 0.0.0.0 x.x.x.97 1
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-sha-hmac
crypto map vpn1 10 ipsec-isakmp
crypto map vpn1 10 match address vpn1
crypto map vpn1 10 set pfs
crypto map vpn1 10 set peer PalHall
crypto map vpn1 10 set transform-set myset
crypto map vpn1 interface outside
isakmp enable outside
isakmp key ******** address PalHall netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
: end
PIX 506: (network 10.128.15.0 needs to access server port traffic on the 10.128.1.0 network)
PIX Version 6.2(2)
hostname PalHall
domain-name PalHall.com
names
name 64.53.6.98 GreenBuilding
name 64.203.210.126 PalHall
access-list vpn1 permit ip host PalHall 10.128.1.0 255.255.255.0
access-list vpn1 permit ip 10.128.15.0 255.255.255.0 host GreenBuilding
ip address outside pppoe setroute
ip address inside 10.128.15.100 255.255.255.0
global (outside) 2 interface
nat (inside) 2 10.128.15.0 255.255.255.0 0 0
access-group testonly in interface outside
access-group testonly in interface inside
crypto map vpn1 10 set peer GreenBuilding
isakmp key ******** address GreenBuilding netmask 255.255.255.255
: end
1 REPLY 1
Beginner
Re: PIX VPN Port traffic not transferring...
I still have not resolved this issue, i need help.
I ran a port scanner across the vpn. I get 2 ports back, 25 and 110. If i try to telnet to those ports i get a blank telnet screen. The IP that im telnetting to should not have email services on it. I'm confused what telnet to port 25 is connecting to on that ip. Regardless, I cant get any other ports to show up across the VPN.
If I could get port traffic across this VPN i would be good to go.
Also, if I cant get anything else off a port scan, how is it I get name resolution and can login to the domain across the VPN?
