PIX515 does not recognize PIX-4FE-66
joopv
Well, the titles says it all....
I have a PIX515 that does not recognize the PIX-4FE-66 that i plug into it. Not even with an UR license installed. Only the 2 onboard adapters are recognized.
The box is running 6.3(3), has 64MB memory (1 module).
Is this a known problem? I'm already waiting for an rma card.
joopv
Ok, i solved the problem myself:
This 515 (new from Cisco, RMA) had a faulty PCI riser card. 2 pins of the connector to the mainboard were badly bend.
Appearantly the PCI slots were not tested before sending the unit to the customer.
