10-24-2002 07:03 AM - edited 03-09-2019 12:48 AM
I have heard a rumor that a program/app/utility exists that will take the access rules and conduits list from the pix and convert it into access lists.
Has anyone also heard this ? Has anyone found this?
Thank you
10-24-2002 08:45 PM
The PIX Output Interpreter will do it for you. Select PIX, then "write term", paste in your config and off you go.
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
10-25-2002 03:22 AM
Wooo Hoooo . That was most painless. Thank you very much.
Took me longer to log in and get there then to get converted to
accesslists and hints on how to improve my pix performance.
Thank you again.
11-26-2002 12:18 PM
Sep 19, 2002, 5:22am PST
Cisco does have a conduit to access list converter, it is hidden in
Under "Technologies" select "PIX" and then paste the entire PIX
configuration into the appropriate field. I would like to thank
Randy Ivener, CISSP
Network Consulting Engineer
Cisco Systems,
for the lead on where to look.
You have to do a show config and get the hole thing into the tool. Part of its output will show the conduits converted to access lists. However it does not take into account that you now have to define acls for sessions intiated on higher security interfaces going to lower security interfaces. It does do converstion of all the existing conduits.
