For Stateful failover for PIX535, it is the connection between PIXs must be Gigabit Ethernet ?
Will it work it I use FastEthernet ??
Can anyone help to clarify the statement on CCO.
Refer to url : http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_70/70hig/535.htm#wp1044120
Step 6 If you are using Stateful Failover, use one of the following types of connections, that is appropriate for your system, between the dedicated interfaces on the PIX security appliance:
Category 5 crossover cable directly connecting the primary unit to the secondary unit
100BaseTX full duplex on a dedicated switch or dedicated VLAN of a switch
1000BaseTX full duplex on a dedicated switch or dedicated VLAN of a switch
Note For Stateful Failover on the PIX 535, you must use a Gigabit Ethernet (GE) failover link with GE interfaces.
