Port-based routing
thegrave2000
I have the following problem: I need to forward all smtp traffic to a specific interface/ip (both interfaces are with public IPs) but in the cmd for creating a static route there's no option to specify a port number. Any idea how to do it? I know how to do it with ip tables but not on a CISCO router. Sorry for the stupid question and thank you in advance
5 Replies 5
nsteup
You have to build an access-list like following:
access-list 100 permit tcp any host xx.xx.xx.xx eq 25
Then use this access-li in a route-map:
route-map mails permit 10
match ip address 100
set ip next hop xx.xx.xx.xx
Now bind this route-map to your inside interface
Hope this helps
Norbert
Thank you very much, I'll tell you the result as soon as I test it!
OK, another stupid question: How do I bind a route-map to an interface, I looked for a cmd but I didn't find anything. Or you mean to bind the access-list?
xxx(config-if)# ip policy route-map yyyyy
Yeah, after reading a couple of documents I made the same conclusion. Thank you for the help once again!
