05-17-2002 06:23 AM - edited 03-08-2019 10:40 PM
This combination of nat should works well?
static (inside,outside) tcp interface 80 10.10.10.10 5800
static (inside,outside) tcp interface 123 10.11.11.11 6700
nat (inside) 1 10.0.0.0 255.0.0.0
global(outside) 1 interface
thanks,
Graziano
05-24-2002 05:57 AM
Looks good at a glance. Is there a specific problem youre trying to find?
05-26-2002 11:50 PM
I only know if is possible to use the keyword "interface" in a static command and in a global command at the same time...
Graz.
