05-12-2003 06:33 AM - edited 03-09-2019 03:15 AM
Dumb question perhaps but I would like to know. Is it possible to somehow pass IPX traffic through a VPN connection if you have a concentrator? I know you cannot do it if your VPN connections terminate at your PIX, but if you had a concentrator, would that make a difference? I have a Novell server that I want people to be able to access if they VPN to us...
Any thoughts? Thanks y'all.
05-12-2003 06:39 AM
You can tunnel all kinds of stuff thru GRE. You would need to figure out how to make a GRE tunnel though - cisco routers can do it. If one end of this connection is end user software though, I can't think of a great solution. Can't you get Novell running IP?
Matt
05-12-2003 06:50 AM
Well...One end will be end user software. It would be nice if I had some hardware at each end, but I don't presently.
We are going to switch to Novell 6 soon...but in the meantime, the IP on our Novell 5 isn't working the way I want it to. Anyways...Thanks for the suggestion. I will look more into that!
