Hi all pix gurus..!
I've set my 501 as shown on the cisco docs (how to set the pppoe client) with a static IP but after a couple of days the connection is out!! Sometimes I can ping outside servers on ip but there's no DNS resolution and when I try to reconnect it's a problem!!
I've no problem of authentication, when I type sh vpdn tunnel, or sh vpdn session, sh vpdn pppint and so on.. everything seems ok.
I've made along time to set the static IP, because when I've typed "ip add outside pppoe setroute" I wasn't be able to conenct from inside, and after some "no ip" and "ip add outside pppoe setroute" OR "ip add outside MYPUBLICADDRESS 255.255.255.0", it's ok..
But what a pain to connect..!
Thz pppoe state is "session up" and when I made my tries it's sometimes in state: "PADR SENT".. (public address sent...??)
If I type directly my ISP static address, I have no default route.... and when I show the remote address (ISP AC) is once a first and the other time another address.. So What to do..?? It's never the same AC, so I can't set manually the default route.
when I type a "sh route" I've the default route (setroute of pppoe) and two others.
What do you think of that..??
