Problems with default route
I have a problem with a MARS (6.1.1), the device loses the default route continuously and we lose the connectivity with it.
I have configured manually the GW but  this doesn´t resolve the problem.
Could help me anyone?
Best regards
Antonio
mwinnett
Level 3
Level 3
Certainly sounds like a defect. As you know, there is nothing to do other than to configure the default gateway. You will probably need to open a tac case. What does "netstat -r" give you ?
Matthew
Hi Matthew,
Sure, I'll open a case with Cisco.
Antonio
