Problems with SSH through IOS firewall
gary.wilcox
I have a CISCO 1711 Security Router connecting a small network to the Internet. If I connect to a server on the Internet from a client on the inside network via SSH, the connection works fine for 20 to 30 seconds then locks up. I can reconnect as many times as I want but the connection only lasts 20 to 30 seconds. Its not the server - I tried the connection thru a different firewall and it works fine.
Any ideas?
nkhawaja
do you have CBAC configured on this router? are there any timeout parameters there?
Nadeem
