08-14-2006 05:17 AM - edited 03-09-2019 03:53 PM
In query settings, specifically Application Control - Tied to Parent and Child Name, the query will literally give the file extension and name (AcroRead32.exe). I want it to simply give the application's brand name (Adobe Acrobat Reader). Does anyone know a way to either get the query to auto change it or if you can set up a file set or something to match the .exe file to an application name?
Also, does anyone know where I can find the list of "variables"...like @process or @netservice
08-18-2006 09:52 AM
Can you specify what version of software ae you using.
08-21-2006 09:56 AM
we are currently using v5.0.0.187
