Question on IP spoof
pokwan
Sometimes I get these messages in the log of our PIX525.
106016: Deny IP spoof from (127.0.0.100) to 10.10.19.90 on interface outside
106016: Deny IP spoof from (127.0.0.100) to 10.10.17.184 on interface outside
These IP addresses are on the inside interface of the firewall. What exactly are the messages conveying?
Thanks.
gfullage
Message details are here:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/syslog/pixemsgs.htm#1022675
Basically the PIX will automatically deny packets from invalid source addresses, of which 127.0.0.100 is certainly one. The PIX is doing it's job and protecting your internal hosts.
If you really want to see what these packets are then you'd have to put a Sniffer on the outside segment and capture them. It may be legitimate traffic from an outside mis-configured host, but most likely it's something bogus. It's probably coming from something directly connected on the outside interface though, cause the 10.x.x.x addresses wouldn't be routed from your ISP to you.
