07-14-2007 12:15 PM - edited 02-20-2020 09:39 PM
Our users authenticate via IAS Radius (active directory). I have one IAS Radius server configured on our concentrator, how would I load balnce Radius adn also create redundancy?
I was thinking if I add a 2nd Radius to the concentrator for authentication for it automatically load balance? And if one IAS server was down would it use the other one?
07-14-2007 08:38 PM
That should work for redundancy. Concentrator will use 2nd radius if the first does not answer. Load balancing will need other method.
John
07-15-2007 04:22 AM
How can I achieve load balance then?
07-16-2007 01:44 AM
Depends on he version of Windows you are running. If you have Enterprise edition you can look at Windows Clustering. If you are running the standard edition then you can have a look at network load balancing. In your case i think you want to look at Network load balancing.
http://support.microsoft.com/kb/323437/
regards
John
07-16-2007 02:29 AM
Could I just add a 2nd Radius server to the concentrator then? and if it can't contact one IAS Radius server then it will try the other one in the list?
07-16-2007 11:37 AM
Yes, that should be fine. Most people use that config. You would only look at clustering and load balancing if you have heaps of athentication connections.
regards
John
