Sampling for ASR1001X
colin.tse1
Dear experts,
We have a ASR1001-X and would like to configure a GRE tunnel for Anti-DDoS service. We input the command “ip flow monitor INTERNET-MONITOR-DDOS sampler SP-SAMPLER input" but the router does not recognize it. Does this command not supported for ASR1001-X? Or there is a missing license or another command will do the same? Kindly please help to advise.
Colin
Cristian Matei
    At which point the commands fails, what is the error message you're getting? Make sure that you have the monitor and sampler already configured with the exact same names, before applying it on the interface.
Cristian Matei.
Thanks Christian. It gives "% Unrecognized command" when putting this command on interface
Apologize for the hassle. We found that there was a typo
Thank you for the support
  @colin.tse1 As said before:  Make sure that you have the monitor and sampler already configured with the exact same names, before applying it on the interface.
Cristian Matei.
