Community Helping Community
108
Beginner
Show authentication sessions interface
I cannot find any document that explains how to interpret the output from the "show authentication session interface" command. I have seen the "Status: Authorized" with what appears to be a valid session, but the "Method Status List: says authentication Failed", does this mean that they hit a failed Authentication Authorization policy that in turn put the user into a authorized state?  Thank You
2 REPLIES 2
Advocate
Re: Show authentication sessions interface
Highlighted
Beginner
Hi Luis, Thank you for your quick response. The document only explains what the possible results are for the Authentication Method, but does not explain what the significance of the results. The snippet I originally posted was from that document and it is just a screen shot of the "Show" command without dissecting it. I was unsure why the authentication would fail, but the port still shows authorized (see the new snippets). I believe it is because there was a authorization rule for failed authentication, but I am not sure. I am new to ISE and DOT1x, so please bear with me. Thanks Again
Content for Community-Ad
FusionCharts will render here
