I've got a problem with shunning on netranger director,when i shun the host on the sensor the sensor does not attempt to send information do the router,and the sensor it's got the right configuration under the device management options and i can telnet to the router manually.please help!!!!,also when i snoop traffic between the sensor and the router the is no communication unless if i telnet manually.
