12-11-2003 05:28 AM - edited 02-20-2020 09:23 PM
Is it possible that a shunning router will leak normally blocked inbound packets? Possibly when the acl numbers are changed on the inbound shunning interface? We're seeing a few packets get through that should be blocked by the pre-shun acl, and were blocked 100% before shunning was enabled. We've confirmed the pre and post shun are correctly in the active shunning acl.
If it can't happen, where should I be looking for the problem?
Considering also applying the pre-shun to opposite interface outbound for a workaround?
12-11-2003 08:37 AM
A related question is: what happens when the cpu hits 100%? Does that affect how the ACL's are handled?
12-11-2003 10:36 AM
Good point. Ours is a 3540 is does peak at 100% briefly now rather than the 50% is was peaking at before shunning.
Can anyone shed some light on these things?
12-15-2003 11:41 AM
Correction, router is 3640.
Anyone else, please?
