02-25-2009 10:54 AM - edited 02-20-2020 09:41 PM
Ok simple question but I have to ask it anyway:
When applying an inbound ACL to a router - does it matter if you apply it to the inside or outside interface?
I have a couple of routers that seem to be configured differently and I'm trying to clean up some of the configs.
One has:
interface FastEthernet0/0.1 (inside)
encapsulation dot1Q 8 native
ip dhcp relay information trusted
ip address x.x.x.x x.x.x.x
ip access-group 101 in
interface FastEthernet0/1.1 (outside)
encapsulation dot1Q 4
Yet another has:
Which is correct?
02-25-2009 11:02 AM
They are both correct depending on how your access lists are written and what you are trying to block and in what direction.
02-25-2009 11:15 AM
In both examples the ACL's are identical, they are permitting inbound traffic from other sites.
So does that make a difference?
02-25-2009 11:49 AM
Yes, look at the source and destination addresses in the acl's. If all of the source addresses are on the outside then the acl would be applied into the outside interface.
