If you have a signature on the IDS to alert/log this as interesting traffic
if you have the sensor on the correct network segment
if you have the the sensor on a SPAN or Monitor port
If If If .....But yes it should. I use Super Scanner to test CSIDS after installation to ensure it is at least seeing and reporting obvious port scans.
