Beginner
Smart Cards and VPN
Does anyone know if Cisco VPN supports H/PC2000 clients?
Khurshid Khan
Re: Smart Cards and VPN
You could get the Movian client from Certicom which runs on these devices as per:
http://www.certicom.com/products/movian/movianvpn_tech.html
Then you could connect it to a Cisco VPN 3000 concentrator. The normal Cisco VPN client doesn't run on PDA or similar devices.
Highlighted
Beginner
But will the movian client work with Cisco IOS vpn?
All the documentation I have found list compatibility with the 3000 and 5000 concentrators.
The Movian client setup requires a group name, user name and group password. I am currently using the Cisco VPN 3.5 client and tacacs+ on our wireless. But also want to be able to use pda's with encryption on the wireless also. Currently running 12.2(t) IOS. Would be nice if movian would work with this IOS wihtout having to buy a 3000 concentrator. Can this be acomplished????
The last time I've heard from Movian, it is not supporting the IOS as yet, but they would be running a beta soon for the newer client release. Maybe you should contact them to get into the beta program.
Ask the Expert- Webex Hybrid Services Solutions
