static PAT statements, need help...
dsingleterry
Hello all,
I am in the process of setting up an email server, for the time being for reasons I'd rather not explain, I cannot put it on the DMZ. So it is sitting on the inside of the 515e firewall interface.
I have the internal IP of that server as 192.168.50.13, and from inside the network I can send , receive, etc email on that server. It is a new server so I recently setup my A and MX records. When pinging the Domain entry the proper IP is now assigned to the Domain name. However I cannot see my email server from the outside world. When running a DNS query on the MX record I get no response.
The problem is at the PIX level. My static statements dont seem to be working.
One of my 4 static statements works, (for our Terminal Services server) but the other 3 entries do not.
They are as follows:
static (inside,outside) tcp MainOffice 3389 192.168.50.75 3389 netmask 255.255.255.255 0 0
static (inside,outside) tcp MainOffice smtp 192.168.50.13 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp MainOffice pop3 192.168.50.13 pop3 netmask 255.255.255.255 0 0
static (inside,outside) tcp MainOffice telnet 192.168.50.201 telnet netmask
255.255.255.255 0 0
(the last entry is just to test and see if I could even host a win2k standard telnet server from my local desktop and see it through the firewall, the test was unsuccessful, I can telnet in via the local IP, .201, but not via the outside IP, MainOffice.)
Since often other places in the PIX config seem to affect the issues I have :), I am including a full running-config listing below for those who would like to reference it. Thank you for your time,
One other strange thing of note, with this current config, I cannot ping my outside interface IP from either external IP's, or from internal IP's. I have my ICMP entries set and thought I should be able to see it, but cant. This isnt as important of an issue as the above issue.
Dave
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security10
hostname YRPCI
domain-name yrpci.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol http 8080
fixup protocol ftp 22
names
name x.x.71.8 ConstOffice
name x.x.81.11 BftOffice
name x.x.71.7 MainOffice
access-list acl_outbound permit ip host 192.168.50.10 any
access-list acl_outbound permit ip host 192.168.50.75 any
access-list acl_outbound permit ip host 192.168.50.201 any
access-list acl_outbound permit ip host 192.168.50.202 any
access-list acl_outbound permit tcp host 192.168.50.203 any
access-list acl_outbound permit tcp host 192.168.50.204 any
access-list acl_outbound permit tcp host 192.168.50.205 any
access-list acl_outbound permit tcp host 192.168.50.206 any
access-list acl_outbound permit tcp host 192.168.50.207 any
access-list acl_outbound permit tcp host 192.168.50.208 any
access-list acl_outbound permit tcp host 192.168.50.209 any
access-list acl_outbound permit tcp host 192.168.50.210 any
access-list acl_outbound permit tcp host 192.168.50.211 any
access-list acl_outbound permit tcp host 192.168.50.212 any
access-list acl_outbound permit tcp host 192.168.50.213 any
access-list acl_outbound permit tcp host 192.168.50.214 any
access-list acl_outbound permit tcp host 192.168.50.215 any
access-list acl_outbound permit tcp host 192.168.50.216 any
access-list acl_outbound permit tcp host 192.168.50.217 any
access-list acl_outbound permit tcp host 192.168.50.218 any
access-list acl_outbound permit tcp host 192.168.50.219 any
access-list acl_outbound permit tcp host 192.168.50.220 any
access-list acl_outbound permit tcp host 192.168.50.221 any
access-list acl_outbound permit tcp host 192.168.50.222 any
access-list acl_outbound permit tcp host 192.168.50.223 any
access-list acl_outbound permit tcp host 192.168.50.224 any
access-list acl_outbound permit tcp 192.168.50.0 255.255.255.0 any eq smtp
access-list acl_outbound permit tcp 192.168.50.0 255.255.255.0 any eq pop3
access-list acl_outbound permit ip 192.168.50.0 255.255.255.0 host 192.168.51.0
access-list acl_outbound permit ip 192.168.50.0 255.255.255.0 host 192.168.52.0
access-list acl_outbound permit ip 192.168.50.0 255.255.255.0 host 192.168.53.0
access-list acl_outbound permit ip host 192.168.50.51 any
access-list acl_outbound permit tcp host 192.168.50.11 any
access-list acl_outbound permit ip host 192.168.50.13 any
access-list acl_outbound permit tcp host 192.168.50.225 any
access-list acl_inbound permit tcp any host MainOffice eq 3389
access-list acl_inbound permit icmp any any echo-reply
access-list acl_inbound permit icmp any any time-exceeded
access-list acl_inbound permit icmp any any unreachable
access-list acl_inbound permit ip host MainOffice any
access-list acl_inbound permit tcp any any eq ssh
access-list 101 permit ip 192.168.50.0 255.255.255.0 192.168.52.0 255.255.255.0
access-list 102 permit ip 192.168.50.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list 100 permit ip 192.168.50.0 255.255.255.0 192.168.51.0 255.255.255.0
access-list 100 permit ip 192.168.50.0 255.255.255.0 192.168.52.0 255.255.255.0
access-list 100 permit ip 192.168.50.0 255.255.255.0 192.168.53.0 255.255.255.0
access-list 103 permit ip 192.168.50.0 255.255.255.0 192.168.53.0 255.255.255.0
pager lines 24
logging on
logging timestamp
logging console debugging
logging buffered warnings
logging trap warnings
logging history warnings
logging host inside 192.168.50.201
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
icmp permit host MainOffice outside
icmp permit host ConstOffice outside
icmp permit any unreachable outside
icmp permit any echo-reply outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside pppoe setroute
ip address inside 192.168.50.1 255.255.255.0
ip address intf2 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
no pdm history enable
arp timeout 14400
global (outside) 2 interface
nat (inside) 0 access-list 100
nat (inside) 2 192.168.50.0 255.255.255.0 0 0
static (inside,outside) tcp MainOffice telnet 192.168.50.201 telnet netmask 255.
255.255.255 0 0
access-group acl_inbound in interface outside
access-group acl_outbound in interface inside
timeout xlate 8:00:00
timeout conn 7:00:00 half-closed 6:00:00 udp 7:00:00 rpc 7:00:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 7:30:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.50.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-sha-hmac
crypto map vpn1 10 ipsec-isakmp
crypto map vpn1 10 match address 102
crypto map vpn1 10 set pfs group2
crypto map vpn1 10 set peer ConstOffice
crypto map vpn1 10 set transform-set myset
crypto map vpn1 20 ipsec-isakmp
crypto map vpn1 20 match address 101
crypto map vpn1 20 set pfs group2
crypto map vpn1 20 set peer BftOffice
crypto map vpn1 20 set transform-set myset
crypto map vpn1 interface outside
isakmp enable outside
isakmp key ******** address ConstOffice netmask 255.255.255.255
isakmp key ******** address BftOffice netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
telnet ConstOffice 255.255.255.255 outside
telnet 192.168.51.0 255.255.255.0 outside
telnet 192.168.52.0 255.255.255.0 outside
telnet BftOffice 255.255.255.255 outside
telnet 192.168.50.0 255.255.255.0 inside
telnet timeout 10
ssh 0.0.0.0 0.0.0.0 outside
ssh 192.168.50.0 255.255.255.0 inside
ssh timeout 20
vpdn group pppoex request dialout pppoe
vpdn group pppoex localname xxxxxxxxx
vpdn group pppoex ppp authentication pap
vpdn username xxxxxxxxxx password *********
terminal width 80
: end
36 Replies 36
Great, as long as email is working. I know most companies consider it the most important service.
that i will definitely buy! good deal...i am glad your moving forward. i love this forum stuff, we not only reinforce the knowledge everyone has but everyone continues to learn. :)
ok, now that we've gone through all of this... for the sheer heck of it I added all the other static lines back in....
you're gonna love this...
its all working now! What's with that?! haha.
I dont know why it wouldnt pick up but now it is on all ports.
I have the following in static now...
55.255 0 0
static (inside,outside) tcp MainOffice telnet 192.168.50.201 telnet netmask 255.255.255.255 0 0
All of which work... (I had to come home to test all of them of course since its hard to do from within the network that the firewall is protecting.)
So, negate what we 'learned'... you can do inbound PAT on a one to many basis. But I still dont understand why it didnt work until I removed all the static lines and added them back in. (that seems to be what changed when it started working since i removed them all to add just one at a time)
So... I dunno, maybe its user error? ha, wouldnt surprise me, but it all works now.
Thanks guys,
Dave
well i'll be a son-of-b!*$@!!!! i have no idea what i am talking about then!!! HA HA.
i am just glad you are working, and maybe someone else watching the boards can help us understand.
Later.
I have seen some weird things the the static mappings on PIX's. I had one issue with a client when I could not get a one to one static map to one server work. I tried everything. After a while, I decided that I would try the mapping a different external address just to test, and it worked. I switched back to the other one and it stopped working. The first IP was in the middle of the range, so I know it wasn't a subnet issue. I ended up calling their ISP and changing their DNS records instead of using that other IP. To make matters worse, later they added a server that needed to be accessed from the internet and I had to use the other IP because it was the only one left in their range, and it worked when I used it with that server. I just chalked it up to one of those computer things I will never figure out.
Can you send me all your static statements AND all your NAT/Global statements (or maybe post your entire working config one last time), I want to check this cause you certainly can create multiple PAT statements to different ports, I've done it plenty of times.
Well, its all working fine now, but here they are anyway. :)
255.255.255 0 0
nat (inside) 10 192.168.50.13 255.255.255.255 0 0
I dont think in need that nat 10 entry, so i'll be taking it out next time im at home and testing to make sure.
