Stub Multicast Routing on FWSM v 2.3.1
f.Medat
Does FWSM v 2.3.1 support Stub Multicast Routing Feature ?
I've found this FAQ which explain that this feature is supported : http://www.cisco.com/warp/public/707/fwsm-faq.html
But I didn't find any documentation how to configure it on a FWSM.
I tried commands provided for PIX 6.2, but it doesn't work :
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_62/config/bafwcfg.htm
Is it a supported feature on this product or a FAQ Bug.
Thanks in advance for your help.
Best regards,
Fabien
umedryk
Level 5
Level 5
Which cat OS version are you currently using ?
We are running a native IOS on SUP720/MSFC:
122-17d.SXB7.
Command is not available on FWSM !
Fabien.
