Teardown vs genuine connection
Proton
Hi All,
I have events for Cisco ASA where I have 2 kinds of connections being built.
Case 1: Genuine Connections:
The genuine connection will only have one entry which will be as follows.
name
deviceEventClassId
Built inbound TCP connection
302013
Case 2: Teardown Connections:
The teardown connection will have the following 3 entries in succession till it reaches teardown.
name
deviceEventClassId
302013
Packet permitted by Access List
106100
Teardown TCP connection
302014
Query:
How will you check for a teardown v/s a genuine connection that has been allowed?
Thanks.
Mike.Cifelli
I am going to provide you with some information that is hopefully beneficial.
I would recommend checking this out: https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/113602-ptn-113602.html
A few other nice-to-knows:
You can utilize the ASA packet tracing tool that will allow you to troubleshoot connections to determine what could potentially be blocking a connection. See here: https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118097-configure-asa-00.html
Depending on your environment something that may occur is asynchronous routing. You can utilize something known as TCP state bypass that simply tells the ASA to disable stateful inspection. See here: https://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/conns_tcpstatebypass.html#wp1088415
HTH!
