04-17-2005 03:59 AM - edited 03-09-2019 10:58 AM
Dear All,
Is there any way to telnet and manage the interface that is getting dynamic ip address from local isp remotly?.
Thanks in advance
swamy
04-17-2005 05:06 AM
hi swamy,
you need to know the IP before managing any router... so, if you gotto telnet to a router, you should have some sort of static/reachable IPs on it.. if you have dynamic, u wont know which IP to telnet to.. once you have the IP reachability and access rights, you can telnet and manage any static IP on a network component.
Raj
04-17-2005 04:15 PM
You can push the limits of dynamically assigned IP addresses by using the FREE services of DYNDNS.ORG. Checkout http://www.dyndns.org/services/dns/dyndns/ where, with the use of a DNS server, you can keep track of your assigned IP address.
