07-30-2007
02:09 AM
- last edited on
02-21-2020
11:17 PM
by
cc_security_adm
I am having some Strange issues regarding throughput between several trunked vlans when passing the ASA.
Constellation:
2960-2 (vlan 1-5) <-- trunk --> 2960-1 (vlan 1-5) <-- trunk --> ASA 5520 (Ge0/1.1-5)
As soon as flows traverse the ASA i have issues with really slow traffic (1-2Mbit max).
I already updated the ASA to the 8ED release but nothing changed.
There is a hint for the problem on the Ge Interface on 2960-1 in terms of "undersize packets"
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
Gi0/2 0 0 0 4 3247978
Consulting the "Troubleshooting Switch Port and Interface Problems" guide i end up with following not so usefull info.
[quote]
This is an indication of a bad frame generated by the connected device. Verify that the connected device operates correctly.
[quote end]
Unfortunately there are no signs of interface errors on the ASA interface and the corresponding subinterfaces.
Anyone a hint how to troubleshoot this the best way or find the source of the problem.
Software Images:
ASA -> 8.0(2)
2960 -> 12.2(35)SE
Thanks for reading...
Roble
08-31-2007 03:08 AM
Having a similar problem with my ASA
Getting around 100Kb/s with a 100Mbit local lan connection.. If I use my older 515E it gives me top notch speed....
08-31-2007 04:08 AM
found my problem, damn switch went half-duplex on me
