06-28-2005 04:55 AM - edited 03-09-2019 11:41 AM
i have two subnet one off 10.x.x.x series and other small just two host of 192.168.100.0 series.
everything from my 10.x.x.x network is working fine.
But noting from 192.168.100.0 series.
pls find my config attached
cheers
Ramp
06-28-2005 05:41 AM
Have you added a route on the pix for your subnet 192.168.100.0 /24 ?
i.e.
route inside 192.168.100.0 255.255.255.0
Can you post your config in note pad format please.
Jay
06-29-2005 05:09 AM
hi jay
i do have the route added
my config is already posted in the zip file attached
cheers
ramp
06-28-2005 06:03 AM
Hi Ramesh,
I dont see any issues with the NAT or Access-list. Try to look for xlate commands to see if 192.168.x.x getting xlated. Then try to debug the failures by using the "logging debugging" feature on see whats going on for real.
MAR
06-29-2005 05:04 AM
