Unconsumed token
darin.marais
Level 4
Level 4
Dear list,
When I run SigWizMenu on our sensors I receive “Unconsumed token(s) [Attempt to parse Non-Numeric value.] passed to parameter "ServicePorts"
What does this mean?
The sensor currently has the following version installed.
>nrvers
Application Versions for Ids1jmo.ce
The Version of the Sensor is: 3.1(3)S49
postoffice v220 (Release) 01/12/14-20:01
fileXfer v175 (Release) 01/07/11-21:48
logger v220 (Release) 01/12/14-19:59
sap v220 (Release) 01/12/14-20:01
sensor v262 (Release) 02/05/08-17:28
manage v220 (Release) 01/12/14-20:00
>.SigWizMenu*
setStorageTimeOut: default value of 300
setMpcPercent: default value of 1
INIT - sigsUserModified =
Startup SigWizMenu v262 (Release) 02/05/08-17:25 : CSIDS Signature Wizard
-Load File: /usr/nr/etc/SigData.conf
Null String passed to String Parameter "SigStringInfo"
-Load File: /usr/nr/etc/SigUser.conf
-Load File: /usr/nr/etc/SigSettings.conf
press ENTER to continue...
jakasper
This is a parser error complaining about the value of ServicePorts. There may be a space or alpha character in a ServicePorts definition that is causing this error.
Could you please get us a copy of your /usr/nr/etc/SigUser.conf file so we can give it a look.
Also, what sig update level are you currently running??
You can email directly to kasper@cisco.com.
Thank you.
-JK
