Beginner
Upgrade NAC from 4.5 to 4.8
Hello everyone
I am about to upgrade a NAC from 4.5 to 4.8 on an implementation that I make in a bank with 1500 users. The upgrade is due because the bank is migrating from PCs to Windows 7
The implementation is in Failover (2) CAS and (2) CAM. the design is Out of Band, Virtual Gateway, and an integration with a Wireless Lan Controller.
I would like to know if when I perform the upgrade of the CAM's and CAS´s to version 4.8 I can still use the Clean Access Agent version 4.5 on the clients???. To perform the migration in several steps
There is a StubAgent for version 4.8? or already included in the Agent 4.8 ??? I Install the StubAgent on all computers in the Bank because they have no administrative rights.
What is the best way to perform the upgrade of the agents that does not impact the users ?
Thank you in advance
Eduardo Navas
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Upgrade NAC from 4.5 to 4.8
Hi Eduardo,
The agent 4.5 is compatible with CAM/CAS 4.8, even if with some restrictions:
http://www.cisco.com/en/US/docs/security/nac/appliance/support_guide/agntsprt.html#wp52084
For example, see also the following notes:
"If you are using CAM/CAS version 4.8 with an Agent version earlier than 4.8.0.32, then either use the Link Distribution requirement or upgrade the Agent to the latest version to use the File Distribution."
"Cisco NAC Agent version 4.5.x is not supported for download from a Release 4.6(1) CAM because the Agent installation file structure is different in Release 4.5(x) as compared to the Agents supported in Release 4.6(1)."
The NAC agent 4.8 does not have any further components needed such as the previous stub for example:
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/48/cam/m_webagt.html#wp1473153
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
5 REPLIES 5
Hi Eduardo,
Fede
Beginner
Hi Fede,
     Pls let me know whether 4.8 release is a stable version or not?
When I upgraded my CAS , it is showing the BUILD_INFO=Experimental. Pls confirm is this ok or shall I fall back to version 4.7.2.
-JP
Hi JP,
NAC 4.8 is surely considered to be stable.
The value "BUILD_INFO=Experimental" under /perfigo/build is purely cosmetic.
Fede
Beginner
Thank You Fede. Thank you very much for your prompt response.
-JP
Highlighted
Glad it helped JP.
Feel free to ping us back for any further questions on NAC in the future.
Fede
