Upgraded ASDM form 5.0 to 5.12, ASDM now won't work
lrossignol
I upgraded from ASDM ver 5.0 to 5.12 and now cannot login via client (wrong ver error message)or via HTTPS did I need to upgrade the PIX at the same time?
Fernando_Meza
Level 7
Level 7
check the version of ASDM from your runnning config matches the new version .. .. it shoudl say
asdm image disk0:/asdm-XXX.bin
if it does not match then you neeed to specify it manually
First, ensure the ASDM file loaded in Flash is specified by the asdm image flash:// command. Second, verify the http server enable command is in the configuration. Finally, verify the host that attempts to load ASDM is permitted via the http
command.
I hope it helps ... please rate it if it does !!!
Fernando_Meza
Level 7
Level 7
command.
