1311
Beginner
URL Filter on SFR Module ASA 5506-X with ASDM
Hi guys
I have a situation when used ASDM to configure the firepower module on the ASA 5506-X.
I create a object to filter a URL for example, cisco.com, but when I put that on my policy, the firepower doesn't do anything and the traffic flow is normal, don't block the web page.
On my laptop, is installed the sourcefire agent 2.5 and the SFR Module have the last version 6.0 and his synchronizes with a Active Directory.
The SourceFire ACL is matching a lot.
Thanks for your help.
Carlos.
2 ACCEPTED SOLUTIONS
Hall of Fame Guru
It looks like you've created
It looks like you've created an object called "permit". Can you share that object definition?
I also see the access control policy is out of date on the device. You should deploy and verify it synchronizes.
Hall of Fame Guru
You're welcome Carlos,
Please mark your question as answered if it has been.
5 REPLIES 5
Hall of Fame Guru
Can you provide a screenshot
Can you provide a screenshot of your Access Control Policy showing the URL policy details?
Also please confirm the URL filtering license is installed and applied.
Highlighted
Beginner
Hi Marvin
Hi Marvin
Yes, I have the license for that feacture.
I see the difference on version 5 to 6 is in the access control policy, on version5 have a button "Create Policy", but on version 6 doesn't have.
Attach the image.
Hall of Fame Guru
Beginner
Hi Marvin
Hi Marvin
I appreciate your help, deploy miss the truth, then run correctly.
Hugs.
Carlos
Hall of Fame Guru
