I'm probably being a bit thick but i cannot get the virtual telnet fucntionality on the FWSM - 1.1(3) working.
relevant Config on FWSM (this is a test setup so the web server/ternminal server and the AAA server are the same IP address - 10.5.1.11 ).
virtual telnet 10.1.1.6
static (inside,outside) 10.1.1.6 10.1.1.6 netmask 255.255.255.255
aaa authentication include tcp/0 outside 10.5.1.11 255.255.255.255 10.6.1.2 255.255.255.255 AuthInbound
access-list acl_outside permit tcp host 10.6.1.2 host 10.1.1.6 eq telnet
access-list acl_outside permit tcp object-group prod_ips host 10.5.1.11
access-list acl_outside permit tcp host 10.2.2.2 host 10.5.1.11 eq 3389
access-list acl_outside permit tcp host 10.2.2.2 host 10.5.1.11 eq www
access-list acl_outside permit tcp host 10.6.1.1 host 10.5.1.11 eq 3389
access-list acl_outside permit tcp host 10.6.1.1 host 10.5.1.11 eq www
access-list acl_outside permit tcp host 10.6.1.2 host 10.5.1.11 eq 3389
access-list acl_outside permit tcp host 10.6.1.2 host 10.5.1.11 eq www
If i try to telnet to the virtual server i can see hits on the access-list but no traffic is being sent back.
The virtual server IP address is a spare IP taken from the subnet range assigned to the outside interface of the FWSM.
