VPN3000 Client using preshare key
wayne.hu
We just bought VPN Concetrator 3005. After instatlled the VPN3000 client, I realized I had no place to put preshare key in the Client configuration. Does VPN 3000 support preshare key?
sajithnair
IPSec group name and password which u define on
the concentrator is nothing but the preshared key.
The same IPSec group name and password needs to be
defined in the client for successful authentication.
To put in the client configuration go to
vpn dialer,select the connection entry ---options--
--properties---select authentication page , there
you are at the right place
