VPN3060 running 4.7.2.K
Richard Burts
Cisco just released version 4.7.2.K which includes a fix for the daylight savings time change. I loaded that version onto a 3060 this morning and am having problems with the concentrator. I wonder if anyone else has loaded this version of code and if so what has your experience been?
Rick
Rick
8 Replies 8
Kamal Malhotra
Hi Rick,
What kinda problems are you facing?
Kamal
Kamal
It is in an endless loop rebooting.
If you want to take a look at it my TAC case is SR605425467.
Rick
Rick
Hi Rick,
I lokked at the TAC case. What was the code running before upgrading?
Kamal
Kamal
About two weeks ago we upgraded from 4.1.7.O to 4.7.2.J. This morning was from 4.7.2.J to 4.7.2.K.
Rick
Rick
Hi Rick,
How memory do you have on the concentrator?
Kamal
Kamal
256 MB
Rick
Rick
Rick,
I'm not sure but that could be a part of the problem :
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_7/472con3k.htm
HTH,
Kamal
Kamal
Thanks for the link to the release notes. I have looked through it and wonder if there were something in particular in the release notes that you are talking about. I have not yet found anything that seems to bear on my particular situation.
The TAC engineer is talking about RMA. I would really like to find a way to get into the concentrator but it keeps rebooting and there is never a prompt on the console to login or be able to do anything. Is there anything on the concentrator similar to rommon on routers that can help recover from this kind of issue?
Rick
Rick
