VPN3k - Load balancing and routing between spokes
m.laporta
Hi Experts.
I'm designing a large-scale VPN3k-based hub-and-spoke network (about 400 spokes).
For redundancy, I need to use at least 2 VPN3k's in the hub, and I'm going to leverage the load balancing VCA feature.
The customer says that communication between two spokes might be occasionally needed. This easy to solve if I have only one VPN3k in the hub, but I'm wondering if it would still work with a couple of load-balancing 3k's.
What would happen if the two spokes terminate their tunnels on different hub 3k's?
Could RRI + RIP/OSPF + an additional router solve the problem? Or maybe the additional router is not needed at all (which would make the Customer happier)?
Any ideas are appreciated
Thank you
michele
dlac455
I'm not able to put a positive spin on this: it won't work. VPN3k's will not route between spokes. The VPN3k will spit the packet out the inside interface, instead of turning it around into the correct tunnel. Good luck!
