WEP to WPA
aksher
Beginner
Beginner
How to we go about migrating from WEP to WPA on AP?
5 Replies 5
John Blakley
Advisor
Advisor
If you want to use just one vlan, then you would need to set under your SSID:
authentication open
authentication key-management wpa
wpa ascii key
Under your radio interface:
int do0
encryption vlan 1 mode ciphers tkip
HTH,
John
HTH, John *** Please rate all useful posts ***
i ve one vlan defined for wireless.
i think we need to change profile settings on the user end.shouldn't we?
Yes. When the clients "switch over", they're going to lose association with the AP. You'll have to change the encryption type under the client from wep to wpa-psk (if windows).
HTH,
John
how do we accomplish this through SMS. through scripts?
You may be able to do that, or through GPO, but I'm not a big Microsoft guy. You'll probably want to contact them to see if there's a way to do this through scripting of some kind. Otherwise, you'll need to send a message out to all of your users describing how to switch over to the new security method.
HTH,
John
Recognize Your Peers
