What are the limitations for shunning devices
pheuch
I remember that I read for older releases, that the IDS system can only shun ip addresses if the ACL of the router is controlled by the IDS only.
I guess that this changed. What is the current status ? Can anybody give me a link to the list of devices (firewall/router) that are supported (sensor is a Cisco Secure IDS 42...) and the limitations ?
Thank you
stleary
Here is a link to the currently supported devices:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids8/13870_01.htm#xtocid20
The main limitation for routers and switches is that IDS must be the sole
controller of the interface/directions which have been configured
for shunning. This has not changed since the older releases.
This does not apply to PIXes however. IDS uses a new shun command
on the PIX, so users can modify PIX ACLs whenever they wish.. The
main limitation for PIXes is that network shuns (as opposed to host shuns)
are not supported.
