why the problem with my confige ?
li-he
i confige ipsec with two router connected by lan :
1)router1 configuration :
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router-7206
enable password cisco
ip subnet-zero
no ip domain-lookup
ip cef
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp key nantian address xx.xxx.xx.xx
crypto isakmp keepalive 30 5
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map mymap 1 ipsec-isakmp
set peer 10.30.1.2
set transform-set myset
match address 101
interface Loopback0
ip address xxx.xx.1.1 255.255.255.0
interface FastEthernet0/0
ip address 10.30.1.1 255.255.255.252
half-duplex
crypto map mymap
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
access-list 101 permit ip 72.1.1.0 0.0.0.255 26.1.1.0 0.0.0.255
line con 0 line aux 0
line vty 0 4
password xxx
login
end
Router-7206#
2)router2 configuration :
version 12.1
hostname Router-2620
memory-size iomem 10
ip subnet-zero
no ip domain-lookup
hash md5
crypto isakmp key nantian address 10.30.1.1
crypto dynamic-map mymap 10
crypto map mainmap 1 ipsec-isakmp dynamic mymap
interface Loopback0
ip address 26.1.1.1 255.255.255.0
ip address 10.30.1.2 255.255.255.252
duplex auto
speed auto
crypto map mainmap
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
ip classless
ip http server
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
Router-2620#
my question :
when i use these command "show crypto ipsec sa" "show crypto isakmp sa " ,nothing is output . what's the problem with my configuration ?
gfullage
Change your default routes on each router to point specifically to the other routers IP address, not just out teh FA0/0 interface. Then do a ping to the others loopback address, making sure you source it from the local routers loopback interface, that should bring the tunnel up.
Remember that the tunnel is only built when traffic is sent, so if you don't do a ping or the like then you won't see the tunnel built.
If it still fails, please run:
> debug crypto isakmp
> debug crypto ipsec
on both routers, try the ping again and send us the output.
yes. i changge the default route to specific route ,and now it run well .Thks.
dpatkins
Do you need a set peer 10.30.1.1 in router2? Or did I overlook something?
