Showing results forĀ
Search instead forĀ
Did you mean:Ā
Windows 7 problem on NAC v4.7.2 with web authentication
s.demosthenous
The problem  experienced on Windows 7 machines is the following:When they connect and authenticate successfully, they are repeatedly redirected to the authentication page and asked to reauthenticate.
Any help?
Thank you,
Stratos Demosthenous
Faisal Sehbai
Level 7
Level 7
Stratos,
This is happening only with Windows 7 machines and others are working fine?
Faisal
If you find this post helpful, please rate so others can find the answer easily
Hello Faisal,
Yes,this is happening only with Windows 7 PCs.
Thank you,
I have perform some onsite triubleshooting and it seems taht the problem is not with all Windows 7 workstations.
The problem apperas only to 2 laptops(same model/brand HP Pavilion) with Windows 7 Home Premium with AVG and Kaspersky installed
I have asked the users to remove the software and try again.
Thank you,
Stratos Demsotehnous
