I was wondering if anyone has already resolved this issue before.
I have a new PC, which has been provisioned for PEAP- MSCHAPv2. There is a phone and pc connecting on thIdentity Service Enginee same switchport. We are running ISE 2.4 in our environment. When connected to Ethernet am seeing error message on ISE as :
Event | 5411 Supplicant stopped responding to ISE |
Failure Reason | 12937 Supplicant stopped responding to ISE after sending it the first inner EAP-MSCHAPv2 message |
Attached the dot1x debug from switch.
Trying to identify what's causing this issue. Thanks in advance for helping me in identifying the issue.
Solved! Go to Solution.
Issue was with the network drivers on the NIC card. Downgraded the dell nic drivers which solved the issue.
Did you resolve this issue already?
