407
DCJCarloLorenzo
Beginner
Zone Based Firewall(ZBF) Device and IOS Compatibility
Guys, Im using Cisco Router 2900series with IOS IOS ver 12.3(14)T. I cannot use ZBF.
1. Is Cisco Router 2900series ZBF capable?
2. What IOS version should I use?
3. Do I need additional License for this feature to be enable?
Thanks in advance for the help!
-Carlo
1 REPLY 1
Karsten Iwen
VIP Mentor
I think you are using a newer IOS. I don't remember that these models run that old IOS versions.
But which version should you use? 15.0.1M10 or 15.2.4M5 are quite stable releases.
For ZBF you need a security license. With "show version" you can see if you have the security license on your device.
Create
Recognize Your Peers
Content for Community-Ad
