Hi Guys,
i try to configure a BRAS solution for PPPoE/A termination.
When try to connect a client i receive the following error:
*May 3 00:51:25.043: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to up
*May 3 00:51:25.046: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access4, changed state to up
*May 3 00:51:25.093: %FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb= 0x40A8D2CC, ifnum= 29
*May 3 00:51:25.098: %LINK-3-UPDOWN: Interface Virtual-Access4, changed state to down
The problem is related to Virtual-Access subinterface, usually, on standard IOS, i work on full mode
In the Cisco DOC i found this:
"If the subinterface is not configured, the following error message is displayed when creating a session with one of the RADIUS attributes:
*Mar 13 22:04:03.358: %FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb= 0x7FA35A42F218, ifnum= 30
To enhance the scalability of per-user configurations, in many cases, different Cisco AV-pairs are available to place the subscriber interface in a Virtual Routing and Forwarding (VRF) instance or to apply a policy map to the session. For example, use the ip:vrf-id and ip:ip-unnumbered VSAs to reconfigure a user's VRF. For information about enhancing scalability see, "Enhancing the Scalability of Per-User Configurations" section."
Ok i try to pass in radreply the following attribute :
test Cisco-AVPair += ip:vrf-id=RACC_ULL
test Cisco-AVPair += ip:ip-unnumbered=Loopback 199
Nothing don't work same error ....
If remove a "ip-unnumbered" attribute the Virtual-Access coming up but no ip address is assigned
Any ideas ?
Many thx
show ver
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.1(3)S2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 12-Dec-11 15:15 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2011 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ASR-01-BS uptime is 6 days, 18 hours, 6 minutes
Uptime for this control processor is 6 days, 18 hours, 8 minutes
System returned to ROM by reload at 22:08:16 UTC Sat Mar 31 2012
System image file is "bootflash:asr1000rp1-adventerprisek9.03.04.02.S.151-3.S2.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco ASR1002 (2RU) processor with 1700062K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
1 ATM interface
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7757823K bytes of eUSB flash at bootflash:.
show run
aaa new-model
aaa group server radius AAA_RACC_ULL
server-private xx.xx.xx.xx auth-port 1812 acct-port 1813 key xxxxxxx
ip vrf forwarding RACC_ULL
aaa authentication login local_auth local
aaa authentication ppp default group AAA_RACC_ULL
aaa authorization network default group AAA_RACC_ULL
aaa accounting send stop-record authentication failure
aaa accounting update newinfo periodic 60
aaa accounting network default start-stop group AAA_RACC_ULL
aaa accounting connection default start-stop group AAA_RACC_ULL
aaa accounting resource default start-stop group AAA_RACC_ULL
aaa session-id common
aaa policy interface-config allow-subinterface
ip vrf RACC_ULL
description *** VRF Raccolta TEST ***
rd 1:1
vpdn enable
no virtual-template snmp
bba-group pppoe xDSL_PPPoE_ADSL
virtual-template 199
vendor-tag circuit-id service
sessions auto cleanup
interface Loopback199
description *** GW RACCOLTA IP ADSL ***
ip address 10.0.0.1 255.255.255.255
interface GigabitEthernet0/0/0
description *** ***
no ip address
no ip proxy-arp
load-interval 30
negotiation auto
interface GigabitEthernet0/0/3.20
description *** DOWNLINK TO DSLAM VLAN ADSL ***
encapsulation dot1Q 20
no ip proxy-arp
pppoe enable group xDSL_PPPoE_ADSL
interface Virtual-Template199
description *** PPPoE AUTH ADSL ***
mtu 1488
ip unnumbered Loopback199
peer default ip address pool DYNAMIC_ADSL
ppp authentication chap pap callin
ip local pool DYNAMIC_ADSL 192.168.20.2 192.168.20.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf RACC_ULL 0.0.0.0 0.0.0.0 192.168.254.1
ip radius source-interface GigabitEthernet0/0/0.999 vrf RACC_ULL
radius-server vsa send accounting
radius-server vsa send authentication
Solved! Go to Solution.
Hi Alessandro,
I understand that you are trying to configure per-user VRF for your session, correct? Would it be possible to share the full Radius profile you are sending? Perhaps you are sending some other attribute that is trying to trigger full VAI which is not supported in ASR1k platform.
Best regards.
Hi Alessandro,
Best regards.
Hi Manuel,
thanks for your answer.
Below the other attribute send from radius to ASR
Framed-MTU := 1488
MS-Primary-DNS-Server := 62.97.32.21
MS-Secondary-DNS-Server := 62.97.33.21
Framed-Protocol := PPP
Service-Type := Framed-User
Framed-Compression := Van-Jacobsen-TCP-IP
If possible i prefer to work using only virtual-template mode without per-user VRF.
I try con configure VT using ip vrf forwarding RACC_ULL and ip unnumbered ( in the same VRF domain ) without success.
I have found the problem ....
Force the virtual-access mode to full.
Many thx Manuel.
Hi Alessandro,
I was about to reply your previous message. Indeed, Framed-Compression attribute will force the use of full VAI. The attribute is not supported on ASR1k platform because of this. You were one step ahead of me there
Best regards.
alessandro
can you share please the exact things you made to solve the issue ?
i have the same problem you have
just worked on radius ?
or added more config on asr ?
Hello I have same problem.
I try remove framed-compression and dosen't work.
this is log:
%FMANRP_ESS-4-FULLVAI: Session creation failed due to Full Virtual-Access Interfaces not being supported. Check that all applied Virtual-Template and RADIUS features support Virtual-Access sub-interfaces. swidb= 0x7F6BAFE869E8, ifnum= 25
