ASR 9006 does not publish my network prefixes
emendez1816
Hello Friend, good afternoon, look, I am starting the configuration of an ASR 9006 and I have problems with the BGP out publication, since I receive prefixes without problems, the issue is to publish prefixes to my peer neighbors, I will share my config if you can help me.
prefix-set Locales
10.240.10.0/24,
10.240.11.0/24
end-set
route-policy pass_all
pass
end-policy
route-policy Locales-OUT
if destination in Locales then
pass
endif
end-policy
router bgp 65000
bgp router-id 10.241.0.1
address-family ipv4 unicast
network 10.240.10.0/24          (Prefixes that I want to publish to my bgp peers)
network 10.240.11.0/24          (Prefixes that I want to publish to my bgp peers)
neighbor 10.241.0.2
remote-as 65000
advertisement-interval 15
description IBGP
route-policy pass_all in
route-policy Locales-OUT out
soft-reconfiguration inbound
end
RP / 0 / RSP0 / CPU0: ASR9006 # show bgp neighbor 10.241.0.2 advertised-count
Fri May 28 11: 43: 06.902 Santiago
No of prefixes Advertised: 0     (There is nothing published)
RP / 0 / RSP0 / CPU0: ASR9006 # show bgp summary
Fri May 28 11: 43: 26.816 Santiago
BGP router identifier 10.241.0.1, local AS number 65000
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000000 RD version: 20
BGP main routing table version 20
BGP NSR Initial initsync version 2 (Reached)
BGP NSR / ISSU Sync-Group versions 20/0
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process RcvTblVer bRIB / RIB LabelVer ImportVer SendTblVer StandbyVer
Speaker 20 20 20 20 20 20
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up / Down St / PfxRcd
10.241.0.2 0 65000 209 191 20 0 0 00:06:49 2    (I get two network prefixes)
Fri May 28 11: 44: 48.698 Santiago
Status codes: s suppressed, d damped, h history, * valid,> best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP,? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> i10.5.4.0 / 24 10.241.0.2 100 0 i
*> i10.18.0.0 / 24 10.241.0.2 100 0 i
Processed 2 prefixes, 2 paths
3 Accepted Solutions
Hi @emendez1816 ,
You could just configure static route to a specific destination or to null0.
router static
10.240.10.0/24 null0
10.240.11.0/24 null0
or
router static
10.240.10.0/24 <next hop address>
10.240.11.0/24 <next hop address>
Static routes to null0 are normally used when you have more specific routes available locally.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi @emendez1816 ,
you need to add a network statement in BGP as follow:
router bgp 65000
network 0.0.0.0/0
and then add a static route for the default route.
router static
0.0.0.0/0 <next-hop address>
or
router static
0.0.0.0/0 null0
You will also need to change the prefix-set Locales to allow the default router.
prefix-set Locales
10.240.10.0/24,
10.240.11.0/24,
0.0.0.0/0
end-set
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Friend,
I see many post about the Network and BGP and the why this network command not work in BGP?
the BGP is depend on RIB in advertise any prefix, if the BGP not see this prefix in RIB then it not advertise it to other BGP Peers
BUT
why we use Network for prefix different than RIB ???
the answer is aggregate, where one method of aggregate many prefix in to single prefix is through the
config this single prefix to NULL0 with static and then use Network in BGP with this new single prefix.
So what happened !!
many config the network for this new single prefix in BGP without  config the static and hence the BGP check the RIB and see there is no prefix and not advertise it to other peers.
11 Replies 11
Harold Ritter
Hi @emendez1816 ,
These two prefixes (10.240.10.0/24 and 10.240.11.0/24) have to exist in the local routing table before BGP originates them via the network statements. They can be either received via a dynamic routing protocol or statically configured.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
How do I configure them statically? for it to be published by bgp?
Hi @emendez1816 ,
router static
or
router static
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks, I will try.
Last question, how do I generate the default route in bgp to send it to my IBGP peers?
What are the commands that I should use to generate the route of 0.0.0.0/0 ??
Hi @emendez1816 ,
router bgp 65000
network 0.0.0.0/0
router static
or
router static
0.0.0.0/0 null0
prefix-set Locales
10.240.10.0/24,
10.240.11.0/24,
0.0.0.0/0
end-set
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
remove policy OUT and try again,
also please more info about the policy OUT, what is if destination
Hi @MHM Cisco World ,
The configured outbound policy is fine. It only permits the two specific routes.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Javier Acuña
Could you give me the output of the commands #sh ip bgp summary
# show ip bgp neigh
In order for you to propagate the network you want, you must configure the BGP family as follows
address-family ipv4
network 10.240.10.0
network 10.240.10.0 mask 255.255.255.0
neighbor 10.241.0.2 activate
neighbor 10.241.0.2 prefix-list default in
neighbor 10.241.0.2 distribute-list prefijos-CANTV out
exit-address-family
remenber to rate
Hi Javier,
The network statements the original poster provided are correct. They are in IOS-XR format. What you are providing is in iOS format.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Friend,
BUT
So what happened !!
